Home > Puma (Tdci) > PUMA Airconditioning problem
Defderico
France 2002 Defender 90 Td5 SW Alaska White
Hi there
I have no aircondtioning in my 110 TDCI 2011. It was good untill I stock the truck for some months due to a gearbox clutch changed
The switch has the light on
The relay is working
Fuse is ok
But the clutch do not engaged
Gaz sound when I push on the valve
I look at the connector on the compressor to see if there is voltage when the incab switch is on : nothing
What should be the voltage : 12 V ?
Any advice will be very appreciate as the summer is already here
Thanks, cheers
May 2025 be a better year
Post #1055959 31st Dec 2024 12:00am
It perhaps needs a re-gas. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1055971 31st Dec 2024 10:13am
bankz5152
Probably needs a regas Instagram @defender_ventures
Empire Tuning - Agent
Post #1055972 31st Dec 2024 10:19am
TexasRover
Did you check the pressure with a cheap Harborfreight AC gauge set? Oh no it's Europe, where you need an expert for everything and "right to repair" is just a popular catch phrase.
No compressor engagement typically means the gas pressure has dropped too low, caused by a leak in the system
Post #1055985 31st Dec 2024 2:14pm
bankz5152
Very angry about that Laughing We can buy AC Pro aircon gauges and refills which is what I use Whistle Instagram @defender_ventures
Post #1055986 31st Dec 2024 2:24pm
Zed
You can buy it in Europe too but itโ€™s also illegal to refill fluorinated gas without proper qualifications in this country. WARNING.
Post #1055995 31st Dec 2024 3:11pm
ickle
Well at least I know where New Caledonia is now.......
Local LeClerc does a refill offer a couple of times a year, โ‚ฌ45 and an hours wait, job done!
Post #1055997 31st Dec 2024 3:20pm
Most UK a/c gas is no longer fluorinated, and the DIY type canisters certainly aren't.
Post #1056000 31st Dec 2024 3:50pm
