Home > Tdi > Transfer box fill plug seized
Page 2 of 2 <12
revd
I remember now how I used not a breaker but a ratchet (Britool) with a box spanner jammed on the handle and a socket and extension on the other end of the box spanner giving about 20” of leverage. I would avoid dismantling anything unnecessarily- you just open up another avenue of grief with something else to break
Post #1054836 16th Dec 2024 1:53pm
SADS wrote:
Can you remove the handbrake housing without taking the propshaft off?
No, but ithe prop shaft is only held on by 4 nuts.
Post #1054837 16th Dec 2024 2:04pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
With plenty of time, its not a bad thing to take bits apart to make sure they are serviceable, accepting the likely failure of parts, exactly as you mention.
But it sounds like the OP does not have that benefit really, so i would, very much, endorse what you are saying!
Post #1054839 16th Dec 2024 2:13pm
Mo Murphy
Taking the prop off and the hand brake / back plate off are 1 spanner difficulty jobs that will let the OP get his breaker bar in.
It sounds like he won't get the filler plug out otherwise.
If he really can't do that then the only other thing to try is a long wobble bar extension to get the breaker back past the handbrake drum.
50 Shades of Pennine Grey
Post #1054843 16th Dec 2024 3:16pm
Roverdrive
Never had an access issue from underneath.
Can't remember if I use a short 1/2" extension with a "wobble" end?
Never had to take the handbrake off.
Post #1054850 16th Dec 2024 3:57pm
SADS
United Kingdom 1990 Defender 90 200 Tdi SW Arles Blue
Update - the plug is out!
I had a second go with the breaker bar to see if it would fit. With a lot of wiggling and gently persuasion, it slotted in and with the added leverage over the ratchet, it cracked loose.
I measures the breaker swivel and it’s 5.5cm.
Will order a new plug. This ones chewed up (it was prior to my ownership).
Post #1054875 16th Dec 2024 7:07pm
SADS
Now, if anyone has any smart ways to access the top bolt on the clutch slave cylinder…?
I also have a normal master cylinder to replace my current, as well as a LOF master cylinder. Would you think 1000 miles into a new clutch is too early to fit the LOF?
Post #1054876 16th Dec 2024 7:10pm
Mo Murphy
The best way to change the clutch master is to remove the clutch pedal box from the bulkhead.
Post #1054916 17th Dec 2024 3:12am
SADS
Yep, its the slave cylinder i cant get off.
Post #1054918 17th Dec 2024 7:08am
Page 2 of 2 <12
