![]() | Home > Tdi > Transfer box fill plug seized |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
No, but ithe prop shaft is only held on by 4 nuts. |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 149 ![]() ![]() ![]() |
With plenty of time, its not a bad thing to take bits apart to make sure they are serviceable, accepting the likely failure of parts, exactly as you mention. But it sounds like the OP does not have that benefit really, so i would, very much, endorse what you are saying! |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2319 ![]() ![]() ![]() |
Taking the prop off and the hand brake / back plate off are 1 spanner difficulty jobs that will let the OP get his breaker bar in.
It sounds like he won't get the filler plug out otherwise. If he really can't do that then the only other thing to try is a long wobble bar extension to get the breaker back past the handbrake drum. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Roverdrive Member Since: 11 Aug 2024 Location: Wirral Posts: 21 ![]() ![]() |
Never had an access issue from underneath.
Can't remember if I use a short 1/2" extension with a "wobble" end? Never had to take the handbrake off. |
SADS Member Since: 28 Nov 2023 Location: Cambridge Posts: 81 ![]() ![]() ![]() |
Update - the plug is out!
I had a second go with the breaker bar to see if it would fit. With a lot of wiggling and gently persuasion, it slotted in and with the added leverage over the ratchet, it cracked loose. I measures the breaker swivel and it’s 5.5cm. Will order a new plug. This ones chewed up (it was prior to my ownership). |
Now, if anyone has any smart ways to access the top bolt on the clutch slave cylinder…?
I also have a normal master cylinder to replace my current, as well as a LOF master cylinder. Would you think 1000 miles into a new clutch is too early to fit the LOF? |
The best way to change the clutch master is to remove the clutch pedal box from the bulkhead.
Yep, its the slave cylinder i cant get off.
