Home > Technical > Windscreen Noise
Jonathanhu22
Windscreen Noise
Can i ask if anyone else experiences a noise from drivers side/top of windscreen when driving
About 70 ish - lets say
Like a creaking noise
Thanks
Post #1054561 13th Dec 2024 11:32am
TexasRover
What car? I a defender or the Disco 6?
If its a defender the corner connection of the roof to windscreen is known to work loose, there is a screw connection which is visible once you remove the headliner. The crew can be loose, you can tighten it, but probably worth looking at replacing it with a hex-head screw and add a bunch of lock-tight in the hope it will stay put.
Post #1054565 13th Dec 2024 11:36am
Jonathanhu22
Defender 110
Thanks
Post #1054567 13th Dec 2024 11:38am
TexasRover
OK assuming then L316, have a look and see if the corner of the roof is coming loose from the window frame
Post #1054570 13th Dec 2024 11:47am
