![]() | Home > Technical > Windscreen Noise |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1228 ![]() ![]() ![]() |
What car? I a defender or the Disco 6?
If its a defender the corner connection of the roof to windscreen is known to work loose, there is a screw connection which is visible once you remove the headliner. The crew can be loose, you can tighten it, but probably worth looking at replacing it with a hex-head screw and add a bunch of lock-tight in the hope it will stay put. |
Jonathanhu22 Member Since: 13 Dec 2024 Location: Midlands Posts: 5 ![]() ![]() |
Defender 110
Thanks |
OK assuming then L316, have a look and see if the corner of the roof is coming loose from the window frame
