Home > Puma (Tdci) > 07 2.4 110 no start (a new thread)
Scorpioinbarnsley
United Kingdom 2007 Defender 110 Puma 2.4 USW Indus Silver
07 110 puma (alisport radiator, intercooler, upgraded turbo, full tank of diesel)
refitted a new vcv valve and now wont start. have BAS tune and i talked to pete but cell service in both our locations is crap so im waiting for his for his reply. but Here is what I did.
Installed new vcv
Installed back to standard tune+recovery
Ran car to 80 degrees
Pilot relearn
High pressure relearn
(car running just fine through all the relearns)
(In here I hit the a10 relearn by mistake but cancelled it)
Installed 160 tune
Car ran for a second and then died out
Installed std tune again x 2
Car ran for about 15 sec and then died
Pulled neg battery lead for 10 min
Installed neg battery lead
Relearned remote key fob. All lights blink according to instructions from internet
Car still does not start
Pulled fuel line at number 4 cylinder. Appears to be no fuel at rail. It’s just me so I cleaned off spill over fuel. Cranked engine, and noticed no fuel coming out due to area still remaining clean.
Reinstalled fuel line
Pulled up live gauges on bad app for rail pressure. Fuel pressure does not appear to move digitally.
Car does not start
let car sit for 3hrs
car doesnt start.
and when i say doesnt start, car cranks just fine but will not kick over due to no fuel
im at a loss now as to why no fuel and im thinking it has something to with immobilzer. at this point im fed up with the puma and im go do a m57 swap anyways. BUT i need the car to move because im over about 6 inches to far on my driveway that i cant get it down the drive and into the backyard to work on it fully. our driveway has a incline so its not like i can just push it forward on my own.
i havent tried the whole pull the whole gauge cluster plug yet but will try that over the weekend. it has to do with something i did with the ECU/a10 relearn but i am at a loss. i did drop a can of seafoam in the diesel tank last week but ive been driving around town prior to today with no issue.
reason i fitted new VCV valvle was because in every 1 in 4-5 starts i would get loss of power. this developed on a long drive last sept on the way home from cornwall. but normally i just restarted the car and it seemed to clear itself out. after reading around here, census was VCV valve so easy shot at that problem.
many thanks in advance. whomever helps me on this, ill get you coffee in town (we are in barnsley).
Post #1053356 29th Nov 2024 6:27pm
You could have ideally just changed the VCV and called it a day, as it will self learn by itself it doesn’t need a learn process, nor does it needs maps changing.
I know hindsight is a wonderful thing but it is true.
What process did you take when fitting the new one itself? (Physically fitting it).
Have you tried the original again? It could be a duff new one, sadly it does happen. TheThunder Rolls🇬🇧🇺🇸
Post #1053357 29th Nov 2024 6:34pm
Scorpioinbarnsley
i have not refitted the old one yet. i did the relearn based off conversation i had with pete @ BAS. but also i did it out of order from his instructions of high pressure reset first then pilot relearn. this was an error on my part. it was running fine with the new VCV while i was getting the engine up to 80 degrees for the relearn process.
Post #1053358 29th Nov 2024 6:38pm
Re-reading your post, you mentioned you removed the fuel line.
You might have an air lock in the fuel line because of that, Pumas can be a bit of a pain to purge air from the fuel line.
In the WSM there is a technique for fuel bleeding I think, but I’ve never done it.
You can get the same with the fuel filter, if it’s not pre filled with diesel.
Then you can get an air lock in the fuel line, this might be what the issue is. TheThunder Rolls🇬🇧🇺🇸
Post #1053360 29th Nov 2024 7:12pm
Scorpioinbarnsley
Don’t think it was air lock because after i fitted the new vcv it ran well when i was bring the car to temp. And then it was running during the whole time of the relearn process. So all this time in total was well into 30-40 min. Which should have been more than enough time for any air if it was in the system to make itself known prior to this no start issue. I’ll look at the airlock issue but I do not think it’s the case.
Post #1053364 29th Nov 2024 7:21pm
There are sensors like the crank position sensor, that I think will allow for cranking but not fire, but the likelihood of that being a failure at the same time to fail is probably unlikely.
Presumably the alarm and immobiliser is synced as you mentioned abd the red dash light is off before cranking.
Have you checked for any logged DTC’s? TheThunder Rolls🇬🇧🇺🇸
Post #1053365 29th Nov 2024 7:33pm
Scorpioinbarnsley
No dtcs. If I can’t get this going by Monday, I’ll just pull the ecu and go to Pete and have the immobilizer removed.
Post #1053366 29th Nov 2024 7:39pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
If it cranks, then it is not the immobilizer.
No fuel? Bleed the system as per manual.
Post #1053409 30th Nov 2024 5:23am
Scorpioinbarnsley
This has been my question I’ve been searching. Does the immbolizer cur fuel or cut crank. The internet is run amuck with lies. But yes it cuts crank. So has to be fuel, and has to be some sort of vapor lock. The next question is why after replacing the vcv which should be the only way for air to enter the system as of recent did it run for so long with no issue. So I’ll bleed the system. But the mystery continues. After this situation I’m 10000000% moving to m57 swap
Post #1053413 30th Nov 2024 7:14am
cretesimon
Greece
Had one 2.4 that won't run was the fuel pump and the pickup in the tank the plastic had cracked and letting in air for the pump I disconnected the fuel feed pipe and put a can with diesel inside and a rubber hose to it put a bit of pressure to make fuel enter pump and opened feed pipes to injectors to check if fuel coming out
Post #1053414 30th Nov 2024 7:25am
It’s very plausible that there is an air leak somewhere, it might be because the VCV has been changed the vacuum pressure has changed somewhat and fuel rail pressure too.
On mine if I’ve ever left the alarm / immobiliser active and started, it would crank, start for about a couple of seconds if that then cut out TheThunder Rolls🇬🇧🇺🇸
Post #1053428 30th Nov 2024 10:14am
Scorpioinbarnsley
this guy wins the prize!!!!!£20 transfer pump from Amazon fixed it!!!! Was vapor locked. Pump on the line, 4 squeezes.. reconnected… gave it some good cranking and fired up.
Post #1053505 30th Nov 2024 8:57pm
That’s what you have to be careful of with the changing of the fuel filter, if it’s not pre primed right to the top you’ll get the same issue with that as well.
Glad you’ve got it fixed, probably be running really nice now with the new VCV. Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #1053554 1st Dec 2024 11:10am
