![]() | Home > Maintenance & Modifications > Rusty rear door lock handle. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 642 ![]() ![]() ![]() |
It is one unit and is replaced by changing the entire assembly.
The late version from 2013 onwards with holes drilled in the handle is counterweighted and nicer to use. Tub striker latch needs a flat filing in it otherwise it fouls the later assembly |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 911 ![]() ![]() ![]() |
Can I put my original lock and barrel onto the new one? 2008 2.4 110 Utility Station Wagon XS.
Trev Member Since: 01 Jul 2023 Location: Fife Posts: 11 ![]() ![]() ![]() |
I was able to swap the lock barrels when I did mine.
![]() New one should be here today. Weekend job added to the list 2008 2.4 110 Utility Station Wagon XS. |
