Home > Maintenance & Modifications > Rusty rear door lock handle.
BrickBox
Evening all.
I have a rusty rear door lock handle and it’s becoming quite brittle. Can I buy a handle separately off a used unit and swap it, or are they complete and the whole lock/handle/mechanism needs replacing?
Thank you Smile 2008 2.4 110 Utility Station Wagon XS.
Post #1052941 25th Nov 2024 9:30pm
Oldowner
It is one unit and is replaced by changing the entire assembly.
The late version from 2013 onwards with holes drilled in the handle is counterweighted and nicer to use. Tub striker latch needs a flat filing in it otherwise it fouls the later assembly
Post #1052956 26th Nov 2024 12:39am
BrickBox
Can I put my original lock and barrel onto the new one? 2008 2.4 110 Utility Station Wagon XS.
Post #1052974 26th Nov 2024 9:44am
Trev
Scotland 2008 Defender 110 Puma 2.4 USW Zermatt Silver
I was able to swap the lock barrels when I did mine.
Post #1053045 26th Nov 2024 9:19pm
BrickBox
Very Happy Cheers all.
New one should be here today. Weekend job added to the list 2008 2.4 110 Utility Station Wagon XS.
Post #1053082 27th Nov 2024 9:29am
