![]() | Home > Maintenance & Modifications > Titanium wheel nuts |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 860 ![]() ![]() |
First World problems eh
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2205 ![]() ![]() ![]() |
Gailing and seizing is common with stainless and Ti. Basically can never use an impact gun you could use a very light coat of ceratec and torque slightly over spec and check regularly. Could just get your nuts painted properly, i redid mine a while back and buzz them on and off fairly often. Paints still acceptable. |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
Don't know if it even exists, but I plasti dipped mine back in the day, held up really well.
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 182 ![]() |
Probably (definitely) cheaper would be to look at a chemical process like cold blackening or parkerising - I've heard of this being done on wheelnuts for another marque and it gives a hard wearing finish that seems to hold up to corrosion / mankiness a lot better than painting.
https://www.madmodder.net/index.php?topic=8995.0 You can buy kits with the chemicals or source your own... |
NMBRPL8 Member Since: 07 Jul 2015 Location: Australia Posts: 150 ![]() ![]() |
I'd be interested to hear what improvement the titanium nuts do to acceleration and cornering.
I've also considered replacing the front light facia with carbon fibre to get the weight down. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1435 ![]() ![]() ![]() |
I use the original wheel nuts on my black bowlers. Which is then complimented by the titanium drive flange bolts. Dirty yes, but no rust
![]() ![]() Click image to enlarge |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3354 ![]() ![]() ![]() |
Looks good mate. How long have the flange bolts been fitted for and have you tried to remove them yet? WARNING.
This post may contain sarcasm. |
Over 12 months…..and yes been in and out a few times CO1 ran them also before he went to the pretender
