Home > Maintenance & Modifications > Titanium wheel nuts
Zed
Titanium wheel nuts
I’m fed up with replacing my black wheel nuts because get tarnished and manky looking so thought I may as well go the other way and try the shiny look with my black Bowler’s. Stainless is the obvious choice but I’ve noticed titanium is rapidly becoming the choice for many enthusiasts and they do look absolutely stunning. I found a specialist locally to make them from the correct grade 5 so no worries about dodgy mislabeled imported stuff that you see on eBay, and whilst not cheap I won’t need to sell a body organ. Which is nice. I have read some stories online about potential strength issue, galling/seizing etc. but not much evidence of it actually happening.
Are there any experts on here that can advise whether this is good idea and also if a specific anti-seize paste would be necessary? WARNING.
Post #1052445 21st Nov 2024 6:12pm
Chicken Drumstick
First World problems eh Laughing
Post #1052450 21st Nov 2024 7:25pm
bankz5152
Re: Titanium wheel nuts
Gailing and seizing is common with stainless and Ti. Basically can never use an impact gun you could use a very light coat of ceratec and torque slightly over spec and check regularly.
Could just get your nuts painted properly, i redid mine a while back and buzz them on and off fairly often. Paints still acceptable. Instagram @defender_ventures
Empire Tuning - Agent
Post #1052454 21st Nov 2024 7:32pm
Likeomg
Don't know if it even exists, but I plasti dipped mine back in the day, held up really well.
Post #1052469 21st Nov 2024 10:34pm
jonny
Probably (definitely) cheaper would be to look at a chemical process like cold blackening or parkerising - I've heard of this being done on wheelnuts for another marque and it gives a hard wearing finish that seems to hold up to corrosion / mankiness a lot better than painting.
https://www.madmodder.net/index.php?topic=8995.0
You can buy kits with the chemicals or source your own...
Post #1052520 22nd Nov 2024 2:14pm
NMBRPL8
Australia
I'd be interested to hear what improvement the titanium nuts do to acceleration and cornering.
I've also considered replacing the front light facia with carbon fibre to get the weight down.
Post #1052757 24th Nov 2024 11:53am
barbel jim
I use the original wheel nuts on my black bowlers. Which is then complimented by the titanium drive flange bolts. Dirty yes, but no rust Whistle
Post #1052762 24th Nov 2024 1:05pm
Zed
Looks good mate. How long have the flange bolts been fitted for and have you tried to remove them yet? WARNING.
Post #1052764 24th Nov 2024 1:17pm
barbel jim
Over 12 months…..and yes been in and out a few times CO1 ran them also before he went to the pretender Laughing Laughing pro bolt supplied, iirc £11 a bolt….. but priceless compared to OCD
Post #1052766 24th Nov 2024 1:28pm
