Home > Td5 > Key cut
Mattz
England 2000 Defender 90 2.5 TD CSW Oslo Blue
Key cut
Hello all, I'm sure thiis has been discussed before, but I couldn't find the thread.
Bent my key trying to open the side door last night when it was frozen. It's not the same as a the ignition key. Does anyone know if I can get this done at a locksmith or do I need to order one from somewhere?
See image.
Matt 2000 Defender 90 Td5 - Oslo Blue
I get in and I smile!
Post #1052427 21st Nov 2024 3:42pm
Mattz
https://www.defender2.net/gallery/albums/u...s%2BLR.jpg 2000 Defender 90 Td5 - Oslo Blue
Post #1052428 21st Nov 2024 3:43pm
90 Dreamer
would think any decent locksmith can sort.........
Post #1052429 21st Nov 2024 3:44pm
Mattz
Wow, fast response - thanks!
Do you know, is it the original key from 2000? 2000 Defender 90 Td5 - Oslo Blue
Post #1052430 21st Nov 2024 3:50pm
TexasRover
No its not, your looks more like a early defender/series door key. Since you say its not the same as the ignition someone probably replaced the door barrels with a cheap series barrel. I recall they are interchangeable with a spacer.
If ever you wanted to get it all back to stock, you can buy a matching set (door and ignition) and is pretty easy to fit.
Post #1052432 21st Nov 2024 4:01pm
Mattz
Thanks m8, I think I'll take that route and change them all.
Cheers! 2000 Defender 90 Td5 - Oslo Blue
Post #1052457 21st Nov 2024 7:48pm
4RF RDS
If you’re getting new keys and barrels, consider doing this mod. Its great. Thumbs Up
https://www.defender2.net/forum/topic16546...p;start=15 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1052663 23rd Nov 2024 4:22pm
Mattz
Thanks very much. Just had a look! 2000 Defender 90 Td5 - Oslo Blue
Post #1052894 25th Nov 2024 3:02pm
