![]() | Home > Td5 > Key cut |
Mattz Member Since: 04 Sep 2024 Location: Hampshire Posts: 11 ![]() ![]() ![]() |
https://www.defender2.net/gallery/albums/u...s%2BLR.jpg 2000 Defender 90 Td5 - Oslo Blue
I get in and I smile! |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2196 ![]() ![]() ![]() |
would think any decent locksmith can sort.........
Wow, fast response - thanks!
Do you know, is it the original key from 2000? 2000 Defender 90 Td5 - Oslo Blue I get in and I smile! |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1153 ![]() ![]() ![]() |
No its not, your looks more like a early defender/series door key. Since you say its not the same as the ignition someone probably replaced the door barrels with a cheap series barrel. I recall they are interchangeable with a spacer.
If ever you wanted to get it all back to stock, you can buy a matching set (door and ignition) and is pretty easy to fit. |
Thanks m8, I think I'll take that route and change them all.
Cheers! 2000 Defender 90 Td5 - Oslo Blue I get in and I smile! |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 962 ![]() ![]() ![]() |
If you’re getting new keys and barrels, consider doing this mod. Its great.
![]() https://www.defender2.net/forum/topic16546...p;start=15 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thanks very much. Just had a look! 2000 Defender 90 Td5 - Oslo Blue
