Home > General & Technical (L663) > Factory fit ACC
Bobbobbobbob
Factory fit ACC
Hi,
Anyone who has factory fit active cruise, are you able to adjust the settings in any way? Other than distance to the car in front.
My previous LR had options on how quickly it got up to the set speed.
I've seen this in the CCF which might do it but maybe not if it doesn't come like that from the factory.
MultiCAN-712 ACC Accel Profile Select
Not supported
Post #1051802 15th Nov 2024 9:03am
Moo
Ukraine
No idea. Don't use it because it's so awful. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1051805 15th Nov 2024 10:03am
Colin68
No can only set speed and distance to the car in front.
Post #1051808 15th Nov 2024 10:24am
Bobbobbobbob
Ok cheers, thought it might get smoother if I could adjust it to a more gentle profile. It's not the best when it's busy but ok as a bit of a safety net on a quiet motorway.
It's not great by LR that the system on my 2014 golf was better.
Post #1051809 15th Nov 2024 10:55am
Colin68
Its the same as my 2022 BMW X4 M40d to be honest
Post #1051811 15th Nov 2024 11:08am
CincyRovers1
United States
You might have to have the ACC recalibrated. I activated it on mine, and it was jerky in stop-and-go traffic. I had it calibrated at the dealer and it has been smooth ever since, but not as smooth as the ACC '23 Porsche Macan S, despite that not having traffic jam assist. ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ‘ ๐๐จ๐ซ๐ฌ๐œ๐ก๐ž ๐Œ๐š๐œ๐š๐ง ๐’ (Dolomite Silver over Black/Bordeaux Red)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ• ๐ƒ๐ข๐ฌ๐œ๐จ๐ฏ๐ž๐ซ๐ฒ ๐‡๐’๐„ ๐‹๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐’๐ข๐Ÿ” (Aintree Green over Vintage Tan/Ebony) - Gone
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐‹๐‘๐Ÿ’ ๐‡๐’๐„ ๐Ÿ“.๐ŸŽ (Ipanema Sand over Almond/Arabica) - Gone
Post #1051841 15th Nov 2024 2:42pm
Bobbobbobbob
Ok thanks, what do they charge for the calibration if you don't mind me asking.
Post #1051848 15th Nov 2024 4:12pm
CincyRovers1
United States
My dealer didn't charge me for the calibration. I assume because I'm still under the factory warranty. ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
Post #1051849 15th Nov 2024 4:31pm
Carpathian110
โ€œYou might have to have the ACC recalibrated. I activated it on mine, and it was jerky in stop-and-go traffic. I had it calibrated at the dealer and it has been smooth ever sinceโ€
So you didnโ€™t have factory installed ACC, you added it yourself using the Gap G4 tool or something similar then had it calibrated for free at the dealer under warranty?
Post #1052177 19th Nov 2024 12:26pm
Moo
Ukraine
Mine came with the car and has been awful from the get go. Itโ€™s been recalibrated by the dealer but is still poor. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1052180 19th Nov 2024 12:47pm
CincyRovers1
United States
That is correct. I told my service advisor that I had it activated with JLR's Pathfinder software, and he (and the service manager) didn't see a problem with it because it was activated using in-house software. It also helps that my dealer has an off-site warranty administrator. ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
Post #1052198 19th Nov 2024 3:54pm
