![]() | Home > Puma (Tdci) > 2.2 clutch problem @ 150K |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 558 ![]() ![]() ![]() |
If I really had to change the plate, I would have the latest clutch model installed (i.e. MY 2015 for the more powerful engine).
But as I said : no signs of failure (rattling, pedal behaviour, or other) but in summer I had the impression that the pedal didn't return "in time" 2 times after long runs on the motorway. I thought this was related to temperatures (35°C) on summer holidays. Since I have a truck licence I am used to engage the clutch more softly in order to avoid primature failures related to harsh impacts on the clutch .... ![]() |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1156 ![]() ![]() ![]() |
"Since I have a truck license", which explains the 6.8t boat haul. Lucky person!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8175 ![]() ![]() ![]() |
6.8 trailer weight or gross train weight?
i readop post as GTW Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6.8 tons - 6200 kg - over all - BE licence can handle it (25 ft sailboat)
The 120 hp tdci engine is near its limits. Climbs slowly. |
The master has been changed.
Clutch is fine. I can move on. ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17619 ![]() ![]() ![]() |
Excellent news, glad to hear it! However at 150k on the original clutch I'd be planning for a clutch change before too much longer.
Right you are !
When I booked the truck in for the leaking Ashcroft spline, we said that the clutch shall be replaced in 2025 for its mileage. Now this issue became even more urgent, because the rubber on the slave might be the same material and be exposed to failure, too. Now, I only have to look for the right part numbers in order to get a MY2015 clutch ![]() By the way, your comments on this thread helped me to figure out where the problem was : ![]() https://www.defender2.net/forum/post971667.html |
