Home > Puma (Tdci) > 2.2 clutch problem @ 150K
Page 2 of 2 <12
To get 150k miles on a 2012 driven plate is pretty good going, they were still not much good in 2012.
By 2012 my '07 110 had done about 100k miles and was as I recall on driven plate number 4, which lasted to about 150k. It is now still on number 5 and is on 277k miles (although it is long overdue for replacing and has very little springiness left). There can be no doubt that recent driven plates are much better than the early ones.
Even if you do end up dropping the transmission out replacing the clutch assembly and slave you have had good value from it. |If you do, you might want to consider using a Transit 4x4 driven plate rather than a LR plate, they seem to be significantly more satisfactory and longer lasting and are a popular choice in Europe.
Post #1051690 14th Nov 2024 8:19am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
If I really had to change the plate, I would have the latest clutch model installed (i.e. MY 2015 for the more powerful engine).
But as I said : no signs of failure (rattling, pedal behaviour, or other) but in summer I had the impression that the pedal didn't return "in time" 2 times after long runs on the motorway. I thought this was related to temperatures (35°C) on summer holidays.
Since I have a truck licence I am used to engage the clutch more softly in order to avoid primature failures related to harsh impacts on the clutch .... Very Happy
Post #1051696 14th Nov 2024 8:52am
TexasRover
"Since I have a truck license", which explains the 6.8t boat haul. Lucky person!
Post #1051712 14th Nov 2024 10:50am
jst
6.8 trailer weight or gross train weight?
i readop post as GTW Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1051720 14th Nov 2024 11:19am
Julie
6.8 tons - 6200 kg - over all - BE licence can handle it (25 ft sailboat)
The 120 hp tdci engine is near its limits. Climbs slowly.
Post #1051740 14th Nov 2024 2:47pm
Julie
The master has been changed.
Clutch is fine.
I can move on. Thumbs Up
Post #1051804 15th Nov 2024 8:51am
Excellent news, glad to hear it! However at 150k on the original clutch I'd be planning for a clutch change before too much longer.
Post #1051815 15th Nov 2024 10:28am
Julie
Right you are !
When I booked the truck in for the leaking Ashcroft spline, we said that the clutch shall be replaced in 2025 for its mileage. Now this issue became even more urgent, because the rubber on the slave might be the same material and be exposed to failure, too.
Now, I only have to look for the right part numbers in order to get a MY2015 clutch Cool
By the way, your comments on this thread helped me to figure out where the problem was : Thumbs Up
https://www.defender2.net/forum/post971667.html
Post #1051821 15th Nov 2024 10:42am
Page 2 of 2 <12
