Home > Td5 > Nanacom question for TD5 2001 90 |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
Hi, I have a TD5 90 2001 with a 10P engine. The ECM is a non-programmable MSB variant.
I own a Nanacom diag system and want to know if I can read the crank position with it? I’ve not been able to find anything in the Nanocom system to let me do this. I’m currently having an issue with starting the truck and want to eliminate the crank/fly wheel sensor. There is nothing in the fault codes for any issue with it but if I disconnect the sensor I still don't get a code error. Can it be read with the setup I have? Thanks in advance. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
11th Nov 2024 6:10am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1115 |
Nanocom can display engine speed (rpm) which is generated by the crank sensor. If the crank sensor is your cause of non-start (quite a likely scenario tbh) you will see the rpm stay at 0 or jumping all over place while cranking
14th Nov 2024 10:54am |
Newlandy Member Since: 01 Apr 2024 Location: Gauteng Posts: 8 |
If you want to test the CPS you can test it by measuring the Ohm between the connectors directly on the sensor, and it should read around 1.2 Ohm.
14th Nov 2024 11:21am |
Thanks for the info guys, much appreciated Mike
14th Nov 2024 6:54pm |
