Home > General & Technical (L663) > HELP complete list of Accessories and suggestions for 110
Page 2 of 3 <123>
Carpathian110
eno wrote:
In relation to the front undershield, the genuine LR one comes with a different (larger?) crossbar, hence the need to remove the bumper and longer installation time. Some other front accessories, like the front expedition protection system, require the crossbar, so if you are considering them maybe the LR undershield might be the way to go
Thanks. Will keep that in mind. I see an aftermarket front under shield from defender retrofit that looks the same as OEM with crossbar and is painted black https://defender-retrofit.uk/product/defen...hield-oem/
Post #1050602 3rd Nov 2024 10:05am
Carpathian110
J77 wrote:
Definitely get the table
Will do
DrRob wrote:
Use www.sidesteps.co.uk
Very happy with mine Thumbs Up
Are these better in quality of other aftermarket steps? There are other steps for less than half that price
Post #1050603 3rd Nov 2024 10:10am
Carpathian110
lightning wrote:
Yeah l love mine as well, but in my enthusiasm made the mistake of buying various accessories that l decided l didn't really need, such as the rear door table, rear spoiler, front under trays, spare set of wheels etc
Ah easily done. I’ve been planning this for a while now and SWMBO needs a brief on everything so sadly I can’t get too enthusiastic or else I’d have this https://newdefendermods.com/collections/al...h-brushbar on the front with offroad tyres!
I don’t think I would ever get a spoiler. I think they look atrocious and have zero purpose on a very purposeful vehicle.
Post #1050604 3rd Nov 2024 10:23am
Carpathian110
DrRob wrote:
Rustrpoofing. Not much is on show due to shields but I’d used XCP on the front and rear subframes etc.
Remove each wheel and spray and wipe etc.
One bottle is enough.
Perfect. Thank you sir
Post #1050605 3rd Nov 2024 10:24am
LR Nuts
Carpathian110 wrote:
Cool. Sounds interesting. Do you have examples and photos of what you’ve done for your L663?
If you go to any of my posts, at the bottom it has a 'tab' named Gallery' Hit that and then at the top of the page is has another 'tab' Thread Uploads, hit that and there are 19 screens of various photos I have posted on the L663 forum.
Post #1050606 3rd Nov 2024 10:30am
Crazymind
LR Nuts wrote:
I buy Land Rovers, as a base vehicle, I add the accessories that I want.
Yes you can buy the 'add-on', but other owners car build the same vehicle as you build.
You can buy the accessories and modify they to suit your requirements.
I build my own accessories, and if other want the same, sorry I only build for myself.
If I want to modify part of the LR built vehicle, I do it myself.
We should not build clones of someone else, otherwise the vehicle stops being yours.
I have a background in engineering/mechanical and electrics with electronics.
Go explore and enjoy your vehicle.
PS I built custom vehicles in the hay day of 70's Very Happy
Thanks for showing off. Very helpfull.
Post #1050608 3rd Nov 2024 11:13am
Crenkz
United States
I have a brand new 2025 P400 Santorini black. Here is what I did immediately:
1. GAP tool
2. Xpel stealth matte PPF from local shop. They did better than factory option for same $.
3. FitcamX dash cam specifically for Defender. I used PowerfulUK console tap-in loom to power the parking mode to avoid having to route any wires to the battery. Super easy to install.
4. Hunter's V3 reverse lights
5. Hunter's rock sliders
Next up:
6. Grill lightbar
7. Garmin Powerswitch to control lights from the Defender's touchscreen with the Garmin app in Carplay. No need to route cables to the switches in the cabin.
8. CanM8 Cannect CANBUS module to provide reverse and highbeam triggers for the Garmin Powerswitch.
See attached pic of the circuit for controlling lights. The reverse lights come on when in reverse but also can be turned on manually from the touchscreen. The hidden light bar white and yellow can be turned on manually from the touchscreen or enabled to be on with highbeams.
Decided to go with ReulSports lightbar instead of the Lucky8 hidden lightbar. The LK8 is not very bright and wont work with the ReulSports hidden winch.
https://www.reulsport.com/en/categorie-produit/defender-new-en/
Post #1050626 3rd Nov 2024 2:16pm
lightning
LR Nuts wrote:
....... and front under trays.
Laughing after all the fuss you made about getting hold of them Confused
I know. But l realised sadly too late what's the point if l don't go off road apart from farm tracks and the odd field
Post #1050644 3rd Nov 2024 6:19pm
Defendit..
Netherlands
Projects:
1. Sound proofing and speaker upgrade:
I also intend on buying some https://standartplast.com/mx/catalog/silve...ck-silver/ to do some sound deadening in the doors for improved acoustics. While I’m doing that it would make sense to upgrade the speakers, I’ve heard 2ohm speakers are good from this thread https://www.defender2.net/forum/topic83928.html but not sure what exact speakers to buy from BLAM. Is this what I need? https://www.blam-audio.com/en/produit/kit-l200p-power/
You can choose Blam Relax, Live or the higher spec Signature, but always max 165mm and 2 Ohm.
For the rear doors don't be afraid to chop a piece/tab of metal in the innerdoor. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1050673 4th Nov 2024 12:50am
Carpathian110
There’s a lot of questions about options and accessories no one has touched on yet. Would really appreciate if I could get folks thoughts on each question… especially those who have already contributed…
Thanks! Also brought the defender out recently for the first time offroad and it was awesome! Chuffed with its performance in muddy trails even with Pirelli all seasons! The traction control is amazing.
Post #1050764 4th Nov 2024 9:56pm
WizzardPrang
Loadspace partition net: very happy with mine, keeps everything in the back where it belongs. Removal or fitting is the work of a few minutes and it folds up really small. Ideal if you often need to drop the rear seats for large loads.
For the genuine LR accessories, you might find this useful for research purposes: https://accessories-instructions.landrover.com/enUSA/new-defender Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1050771 4th Nov 2024 11:10pm
Carpathian110
I think I’ve pretty much done all my research now (at least what I can justify…) I hope but thank you for sharing, it is a great resource to have
Post #1050774 5th Nov 2024 12:11am
A1C6
Australia
Where'd you buy that table?
Post #1051056 8th Nov 2024 11:27am
J77
Powerful UK Thumbs Up 24MY 90 D250 HSE, Tasman Blue
Post #1051088 8th Nov 2024 6:39pm
Moo
Ukraine
There are loads out there. Just have Google. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1051103 8th Nov 2024 8:51pm
Page 2 of 3 <123>
