Home > Puma (Tdci) > Light leveling motors constantly running
Siwynne
My light levelling motors are constantly running. Everything seems to be connected properly but they run when ignition is on with or without engine running. Any suggestions as to why this would be are welcome
Post #1049352 21st Oct 2024 5:23pm
LR90XS2011
Take a look at the levelling switch they can fail DEFENDER 90 TDCI XS,
Post #1049361 21st Oct 2024 6:39pm
Siwynne
Will do
Post #1049366 21st Oct 2024 7:19pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I had this on one headlight and that was simply a faulty adjuster motor. Replacing the motor with a new unit was the fix. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1049397 22nd Oct 2024 6:38am
rustandoil
If you find that your switch is faulty, I would be interested in taking it off your hands, mainly to fill the hole up in my dash Whistle
Post #1049433 22nd Oct 2024 12:45pm
andy63
Have you checked a wiring dig..
I had a quick look and it doesn't appear immediately obvious what the ignition switch has to do with it..it looks to be wired directly to the battery through a fuse and the main lighting switch..
Could the motors be picking up a feed from another source?
Post #1049440 22nd Oct 2024 1:52pm
NickMc
FBV000070PMA About £3 Thumbs Up
Post #1049441 22nd Oct 2024 1:56pm
andy63
after a quick look at the wiring dig the other day in an attempt to offer an explanation to the op's post I sort of guessed there might be a bit more to the way in which the levelling motor works..I sort of assumed that it might be as simple as the window motors ,, but it looks like there is a bit more to the wiring.. not in a position to do any checks myself atm , so thought id ask, does anyone know the method of operation???
is the dash switch a variable resistance and does the motor assembly also have some sort of variable resistance giving feed back on its position?????
Post #1049539 23rd Oct 2024 1:02pm
andy63
Some may be interested..
I found a bit info on levelling motors and their controller which i think may be similar to the defender set up..
It a bit involved but you can get the idea..
A faulty resistance track on the motor feedback would cause the motor to run on , but you have both running on and on an ignition live which the wiring dig I looked at doesn't seem to suggest is the normal feed in to the motor control as far as I can see..it's direct from battery through the lighting switch..
https://www.google.com/search?q=verificati...gws-wiz-hp
Post #1049626 24th Oct 2024 9:58am
rustandoil
...I have the blank, I was thinking about somthing a little more "interesting" to fill the hole Thumbs Up
Post #1049628 24th Oct 2024 10:23am
Siwynne
Thanks for the suggestions and effort. I have not yet had chance to get a multimeter on any of it but will by the end of the weekend and then I’ll post an update
Post #1049646 24th Oct 2024 1:02pm
