![]() | Home > Puma (Tdci) > Light leveling motors constantly running |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3659 ![]() ![]() ![]() |
Take a look at the levelling switch they can fail DEFENDER 90 TDCI XS,
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 593 ![]() ![]() |
Will do
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 910 ![]() ![]() ![]() |
I had this on one headlight and that was simply a faulty adjuster motor. Replacing the motor with a new unit was the fix. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 789 ![]() ![]() ![]() |
If you find that your switch is faulty, I would be interested in taking it off your hands, mainly to fill the hole up in my dash
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 642 ![]() ![]() |
Have you checked a wiring dig..
I had a quick look and it doesn't appear immediately obvious what the ignition switch has to do with it..it looks to be wired directly to the battery through a fuse and the main lighting switch.. Could the motors be picking up a feed from another source? |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
FBV000070PMA About £3 ![]() |
after a quick look at the wiring dig the other day in an attempt to offer an explanation to the op's post I sort of guessed there might be a bit more to the way in which the levelling motor works..I sort of assumed that it might be as simple as the window motors ,, but it looks like there is a bit more to the wiring.. not in a position to do any checks myself atm , so thought id ask, does anyone know the method of operation???
is the dash switch a variable resistance and does the motor assembly also have some sort of variable resistance giving feed back on its position????? |
Some may be interested..
I found a bit info on levelling motors and their controller which i think may be similar to the defender set up.. It a bit involved but you can get the idea.. A faulty resistance track on the motor feedback would cause the motor to run on , but you have both running on and on an ignition live which the wiring dig I looked at doesn't seem to suggest is the normal feed in to the motor control as far as I can see..it's direct from battery through the lighting switch.. https://www.google.com/search?q=verificati...gws-wiz-hp |
...I have the blank, I was thinking about somthing a little more "interesting" to fill the hole ![]() |
Thanks for the suggestions and effort. I have not yet had chance to get a multimeter on any of it but will by the end of the weekend and then I’ll post an update
