Home > Technical > AS10 removal - map changes
Dr Phibes
Australia
Hi
Does anyone know how to change a NNN ECU map to delete the AS10 immobiliser?
Post #1049125 19th Oct 2024 10:33am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Think bell auto services can do that Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1049132 19th Oct 2024 11:10am
Dr Phibes
Australia
I want to do it myself. MEMS3 looks promising.
https://andrewrevill.co.uk/MEMS3LiveMapping.htm
Post #1049141 19th Oct 2024 1:57pm
Dr Phibes
Australia
Has anyone used MEMS3 with a 15P Defender, NNN ECU? It seems to have been developed for the Disco 2. Cant see why it wouldn’t work…
Post #1049184 20th Oct 2024 1:43am
Julie
My last info is that you may have it deactivated but the AS10 cannot be removed. In Pumas & TD5 at least....
Post #1049578 23rd Oct 2024 8:02pm
Dr Phibes
Australia
It can be removed by changing a value in the ecu map/firmware. Empire tuning and others do it. I just want to find out the address to change so I can DIY!
Post #1049581 23rd Oct 2024 8:48pm
Ianh
It’s a 10AS NOT an AS10 Rolling Eyes and yes can be mapped out
Post #1049595 23rd Oct 2024 10:33pm
Dr Phibes
Australia
Yes, freudian slip that shows my disregard for anything made by lucas
Do you know the address/value?
Post #1049597 23rd Oct 2024 11:05pm
NickMc
Don’t think anyone is going to hand out that info for free. You can “remove” it, but it controls your interior lights, central locking etc. So when they say map it out, basically they’re stopping it looking for the rolling code. The box will still be there unless you rewire that. I have done that with td5 looms in Tdis
The other thing you could try is these mini guys in Germany
https://www.m1n1.de/en/bypass-land-rover-l...mobilizer/
Post #1049601 24th Oct 2024 1:14am
Dr Phibes
Australia
Post #1052291 20th Nov 2024 12:24pm
Dr Phibes
Australia
Pleased to report that I have done it.
I will do a proper write up later, but essentially:
Desoldered 93C66 EEPROM
Used an Arduino to zero out register
Resoldered
Ground starter relay pin that’s normally connected to 10AS. Can be switched for manual immobiliser.
Removed 10AS
In my case I am completely replacing central locking, manually control interior lights, and don’t want an alarm- I have other measures including an optimill swivel lock[/list][/list]
Post #1052727 24th Nov 2024 1:29am
