![]() | Home > Technical > AS10 removal - map changes |
Dr Phibes Member Since: 24 Apr 2024 Location: Melbourne Posts: 71 ![]() ![]() |
Hi
Does anyone know how to change a NNN ECU map to delete the AS10 immobiliser? |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 832 ![]() ![]() ![]() |
Think bell auto services can do that Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
I want to do it myself. MEMS3 looks promising.
https://andrewrevill.co.uk/MEMS3LiveMapping.htm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 571 ![]() ![]() ![]() |
My last info is that you may have it deactivated but the AS10 cannot be removed. In Pumas & TD5 at least.... |
It can be removed by changing a value in the ecu map/firmware. Empire tuning and others do it. I just want to find out the address to change so I can DIY!
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2235 ![]() ![]() |
It’s a 10AS NOT an AS10
Yes, freudian slip that shows my disregard for anything made by lucas
Do you know the address/value? |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Don’t think anyone is going to hand out that info for free. You can “remove” it, but it controls your interior lights, central locking etc. So when they say map it out, basically they’re stopping it looking for the rolling code. The box will still be there unless you rewire that. I have done that with td5 looms in Tdis
The other thing you could try is these mini guys in Germany https://www.m1n1.de/en/bypass-land-rover-l...mobilizer/ |
Looks promising: https://forums.lr4x4.com/topic/93558-removal-of-td5-immobilizer/
Pleased to report that I have done it.
I will do a proper write up later, but essentially: Desoldered 93C66 EEPROM Used an Arduino to zero out register Resoldered Ground starter relay pin that’s normally connected to 10AS. Can be switched for manual immobiliser. Removed 10AS In my case I am completely replacing central locking, manually control interior lights, and don’t want an alarm- I have other measures including an optimill swivel lock[/list][/list] |
