Home > Td5 > Oil misting on air filter |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2614 |
The air box only pulls air from the outside world and not recirculated from the engine ( unlike my Turbo Diesel that would make a real mess of the air filter and the common fix would be to disconnect the breather so that it was directed towards the chassis).
At a very rough guess you could check first that the air filter installed isn’t actually an ‘oiled’ filter like a Piper Cross or K&N, other wise take out the inlet pipe and give it a wash in soapy water, dry and replace. Apart from that I can’t see how oil could get to the filter. |
10th Oct 2024 10:58am |
Biscuits Member Since: 27 Mar 2023 Location: Kent Posts: 48 |
Thanks for the info, looks like I've been looking at TDI and not TD5 info previously.
I have found this diagram, which confirms the only engine>intake connection is after the airbox and MAF/MAP sensors. https://www.lrworkshop.com/diagrams/land-r...lter_53455 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
10th Oct 2024 11:17am |
