Home > Off Topic > Latest generation Ford Transit Custom - stereo
Caterham
so rather disappointingly the transit (as per the last one) does not have rear speakers fitted, nor does the head unit have a fader.
the torneo does and as you probably know they're kinda the same thing. the van rear door cards are set up to have speakers and I've no doubt the wiring is there.
does anyone know any tech wizards that can set the head unit up for rear speakers?
I'm happy to fit em - I just need the electrickery / programming sorted?
Post #1047198 29th Sep 2024 2:24pm
I expect the outputs are there, just not in use and need identifying.
Then run new speaker wires.
I don’t know what connectors it uses, but whatever connectors that is used if not DIN ISO, you’ll likely need matching pins if not present.
Or there could be isolated tails coming out from the rear that you can pick up on.
If you do attempt to hardwire it to fit aftermarket HU over to DIN ISO.
You’d need to be sure that other features aren’t knocked out, as some cars use the wiring for other things like fuel estimate gauges etc.
Really you could do with the manufacturers wiring schematic to identify exactly what each feed, and connector type is, but you may find and I think is quite possible that there is wiring tails there present, but not used for the rear feeds. Thumbs Up Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
Post #1047212 29th Sep 2024 4:09pm
Caterham
my understanding is the wiring is all there and connected to the head unit.
just need the speakers installing and the head unit programmed to the 4 speaker configuration....thats where a Ford tech wizard is required Big Cry
or another wizard...my reckoning is that there may be a significant market if someone can figure out how to do it.
on the previous generation someone found the relevant line in the programming - then its a case of finding a similar vehicle with the correct line of data for the 4 speaker set-up and copying over that line of data.....or something like that Banging Head
Post #1047217 29th Sep 2024 4:57pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Some car stereos the fader menu only appears when the rear speakers are connected.
I am sure I had this on an old ford.
Post #1047239 29th Sep 2024 9:04pm
^^ I’ve heard of that, probably detects the impedance of the load.
Are the already fitted in? If not, might be worth fitting them in anyway first and go from there. Play Stupid Games, Win Stupid Prizes.
Post #1047255 30th Sep 2024 8:41am
Caterham
thats my plan (fit em first)
I'd be both impressed and very pleased if it works Mr. Green Thumbs Up
think I've read it won't with the transit and this from the IDS or ACM is required changing ???
Location
727-01-02: xxxx-x*xx-xxxx
Values
0=Speaker3 00-Non-Tweeter Only, Speaker4 00-Non-Tweeter Only
1=Speaker3 00-Non-Tweeter Only, Speaker4 01-Tweeter Only
2=Speaker3 00-Non-Tweeter Only, Speaker4 10-Speaker, Tweeter
3=Speaker3 00-Non-Tweeter Only, Speaker4 11-No speaker Connected
4=Speaker3 01-Tweeter Only, Speaker4 00-Non-Tweeter Only
5=Speaker3 01-Tweeter Only, Speaker4 01-Tweeter Only
6=Speaker3 01-Tweeter Only, Speaker4 10-Speaker, Tweeter
7=Speaker3 01-Tweeter Only, Speaker4 11-No speaker Connected
8=Speaker3 10-Speaker, Tweeter Only, Speaker4 00-Non-Tweeter Only
9=Speaker3 10-Speaker, Tweeter Only, Speaker4 01-Tweeter Only
A=Speaker3 10-Speaker, Tweeter Only, Speaker4 10-Speaker, Tweeter
B=Speaker3 10-Speaker, Tweeter Only, Speaker4 11=No speaker Connected
C=Speaker3 11-No speaker Connected, Speaker4 00-Non-Tweeter Only
D=Speaker3 11-No speaker Connected, Speaker4 01-Tweeter Only
E=Speaker3 11-No speaker Connected, Speaker4 10-Speaker, Tweeter
F=Speaker3 11-No speaker Connected, Speaker4 11-No speaker Connected
Notes
Only Valid if A2B is Enabled.
Post #1047257 30th Sep 2024 9:30am
