Home > Off Topic > Latest generation Ford Transit Custom - stereo |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 |
so rather disappointingly the transit (as per the last one) does not have rear speakers fitted, nor does the head unit have a fader.
the torneo does and as you probably know they're kinda the same thing. the van rear door cards are set up to have speakers and I've no doubt the wiring is there. does anyone know any tech wizards that can set the head unit up for rear speakers? I'm happy to fit em - I just need the electrickery / programming sorted? |
29th Sep 2024 2:24pm |
my understanding is the wiring is all there and connected to the head unit.
just need the speakers installing and the head unit programmed to the 4 speaker configuration....thats where a Ford tech wizard is required or another wizard...my reckoning is that there may be a significant market if someone can figure out how to do it. on the previous generation someone found the relevant line in the programming - then its a case of finding a similar vehicle with the correct line of data for the 4 speaker set-up and copying over that line of data.....or something like that |
29th Sep 2024 4:57pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 |
Some car stereos the fader menu only appears when the rear speakers are connected.
I am sure I had this on an old ford. |
29th Sep 2024 9:04pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 |
^^ I’ve heard of that, probably detects the impedance of the load.
Are the already fitted in? If not, might be worth fitting them in anyway first and go from there. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Sep 2024 8:41am |
thats my plan (fit em first)
I'd be both impressed and very pleased if it works think I've read it won't with the transit and this from the IDS or ACM is required changing ??? Location 727-01-02: xxxx-x*xx-xxxx Values 0=Speaker3 00-Non-Tweeter Only, Speaker4 00-Non-Tweeter Only 1=Speaker3 00-Non-Tweeter Only, Speaker4 01-Tweeter Only 2=Speaker3 00-Non-Tweeter Only, Speaker4 10-Speaker, Tweeter 3=Speaker3 00-Non-Tweeter Only, Speaker4 11-No speaker Connected 4=Speaker3 01-Tweeter Only, Speaker4 00-Non-Tweeter Only 5=Speaker3 01-Tweeter Only, Speaker4 01-Tweeter Only 6=Speaker3 01-Tweeter Only, Speaker4 10-Speaker, Tweeter 7=Speaker3 01-Tweeter Only, Speaker4 11-No speaker Connected 8=Speaker3 10-Speaker, Tweeter Only, Speaker4 00-Non-Tweeter Only 9=Speaker3 10-Speaker, Tweeter Only, Speaker4 01-Tweeter Only A=Speaker3 10-Speaker, Tweeter Only, Speaker4 10-Speaker, Tweeter B=Speaker3 10-Speaker, Tweeter Only, Speaker4 11=No speaker Connected C=Speaker3 11-No speaker Connected, Speaker4 00-Non-Tweeter Only D=Speaker3 11-No speaker Connected, Speaker4 01-Tweeter Only E=Speaker3 11-No speaker Connected, Speaker4 10-Speaker, Tweeter F=Speaker3 11-No speaker Connected, Speaker4 11-No speaker Connected Notes Only Valid if A2B is Enabled. |
30th Sep 2024 9:30am |
