Home > Puma (Tdci) > Need help! — Puma Crew Cab Transfer Mount Issue
yeco
Costa Rica 2008 Defender 110 Puma 2.4 DCPU Cairns Blue
Hi all,
I’m having an issue with the transfer mount on my 2008 Land Rover Defender Puma crew cab (DCPU). The original mounting bracket was stolen, so unfortunately, I don’t have it as a reference. I recently got a new mount plate and support, but when I tried to fit them, I noticed there’s a huge gap.
Here’s a video that shows the problem: https://share.icloud.com/photos/011C6H62Xtltq5fvigFpWCYvA
Some pics:
I’m wondering if this could be due to a difference in mounting plates between the crew cab (DCPU) and the station wagon models. Does anyone know if the DCPU uses a different mounting plate compared to the station wagon, or if there might be another explanation for the gap?
Any help, advice, or experience with this issue would be greatly appreciated!
Thanks in advance.
Post #1046707 24th Sep 2024 11:48pm
landy andy
Are you changing both mounts?
KQB500550 RH SIDE
KQB500560 LH SIDE
I don’t think the dcpu will have any difference with other models.
Post #1046715 25th Sep 2024 7:40am
Re: Need help! — Puma Crew Cab Transfer Mount Issue
yeco wrote:
... I’m wondering if this could be due to a difference in mounting plates between the crew cab (DCPU) and the station wagon models. Does anyone know if the DCPU uses a different mounting plate compared to the station wagon, or if there might be another explanation for the gap?
There is no difference between the different variants, and every Puma Defender should have the same mounts.
Offhand I can't explain the gap, but I am sorry to hear that it was stolen. What an odd thing to steal!
Post #1046716 25th Sep 2024 7:46am
yeco
KQB500550 RH SIDE
KQB500560 LH SIDE
No, just sourced the bracket used and it came with the mount, which seems in good condition.
Post #1046726 25th Sep 2024 8:37am
Dinnu
Very strange. Dont think you can get the mounts swapped left to right because of an orientation dowel.
I doubt if the pics in the below thread can shed any light.
https://www.defender2.net/forum/post865316.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1046732 25th Sep 2024 9:23am
Dinnu
I am not with my Defender to check, but if I look at the mounts for sale on this ebay link, it seems like you have the wrong bracket.
https://www.ebay.co.uk/itm/296512338761?_s...SwOk5mcafV 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1046751 25th Sep 2024 11:46am
I agree with Dinnu, the bracket you have been supplied with is not the correct bracket for a Puma.
I think you've been supplied with ANR2898, you should have been supplied with KQE500050 which looks like this.
Note the relative positions of the holes to mount to the transfer box and the holes for the resilient mount, they are quite different to yours.
Post #1046759 25th Sep 2024 12:22pm
yeco
Oh my. Seems like you’re right folks! It’s the flipping wrong bracket. Thank you so much for noticing!
The mount is the same, right?
Post #1046770 25th Sep 2024 1:36pm
Yes, I believe that the mount is the same, just the bracket is different.
Post #1046771 25th Sep 2024 1:39pm
