Home > Technical > unidentified disconnected cable connector Defender 2007 Puma
PeterA
United Kingdom 2007 Defender 110 Puma 2.4 PU Fuji White
Defender 110 fitted with puma engine 2007.
I have just had to fit a new starter motor and whilst underneath found a disconnected cable. I can not see where it would go and appears to have a very short lead from the cable harness.
It is a single spade connector which considering the age seems quite bright but it has two wires connected to it one is Black with green stripe and the other appears to be blue with either orange, brown or red stripe. It is located on the left hand side of the engine
behind what I believe to be the oil pressure sensor. I have identified the part with an arrow on the picture.
I have searched the wiring and connector databases but can't seem to get a match with the connectors wire colours
Everything with the defender appears to be working with no faults indicated
Can anyone identify it please
Post #1046483 22nd Sep 2024 2:59pm
Martin
Site Admin
The “spade” you can see is plastic, and is on the blanking plug fitted to the connector in the factory. It isn’t supposed to fit anywhere.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1046487 22nd Sep 2024 3:10pm
PeterA
Thank you Martin I must admit I didn't check to see if it was metal. In the light I was working in it certainly looked like bright metal but now you have said it I can see the inserted blanking piece
Post #1046489 22nd Sep 2024 3:19pm
