![]() | Home > Technical > unidentified disconnected cable connector Defender 2007 Puma |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
The “spade” you can see is plastic, and is on the blanking plug fitted to the connector in the factory. It isn’t supposed to fit anywhere.
PeterA Member Since: 04 Feb 2016 Location: Devon Posts: 9 ![]() ![]() ![]() |
Thank you Martin I must admit I didn't check to see if it was metal. In the light I was working in it certainly looked like bright metal but now you have said it I can see the inserted blanking piece
