Home > Technical > Low horn loss!
Gal Dove
Wales 2014 Defender 110 Puma 2.2 USW Corris Grey
Low horn loss!
Hi!!
Puma 2.2 110 Utility (MY 2014).
Just noticed that my low tone horn seems to have stopped working - the high tone one is ok.
Mine is located on the N/S - so I've tried spraying some contact cleaner in there and checked the connections - still no low horn!
Just thought I'd ask here before I buy a replacement low horn - is the existing one fixable (am I missing something that I could try) - and if not, where would be the best place to get a new one (OEM or after market?).
Or... are there any other recommendations for any alternative horns...?
Thumbs Up
Post #1046012 17th Sep 2024 12:45pm
You can test what voltage it receives if you are able to, and see if it has a good ground with a continuity check.
If both of those check out with the correct readings then you might be right that the horn is needing to be replaced. $W33T $0U7H3RN $UG4R
Post #1046020 17th Sep 2024 2:25pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
They often come back to life you you give them a knock - with something like the handle of a screwdriver.
Best done with power to the horn.
Post #1046022 17th Sep 2024 3:17pm
