Home > Technical > Low horn loss! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 |
You can test what voltage it receives if you are able to, and see if it has a good ground with a continuity check.
If both of those check out with the correct readings then you might be right that the horn is needing to be replaced. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
17th Sep 2024 2:25pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 323 |
They often come back to life you you give them a knock - with something like the handle of a screwdriver.
Best done with power to the horn. |
17th Sep 2024 3:17pm |
