Home > Off Topic > APPLE Expert required
walfy
Before the haters start, I love my Apple kit and will not change.
I have a client where I work as a consultant. They have given me a workstation with 2 screens, which is more than I normaly get when I work at client sites.
But the issue I have is getting the screens to work. I can get a picture on the 2 screens but they seem to work independently.
If I log in to the clients server on screen 1, when I open a new window/file it opens on that screen but I can't drag it to another screen to look at it while I work on something else on the server. Not sure it that makes sense.
A quick gogle says I need a docking station? Does anyone have any recommendations? I don't want to spend money to find it doesn't work.
I currently have a little block thing with various ports to enable the second screen, so 1 screen is direct via the HDMI port, second screen is via this block and then in via the USB C port. 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #1044889 5th Sep 2024 10:33am
Moo
Ukraine
This might help.
https://support.apple.com/en-gb/117373 Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1044890 5th Sep 2024 10:35am
walfy
Went to Apple to begin with but I got lost in the tech jargon.
I have a Macbook Pro with M1 pro chip set. But their blurb made no sense to me.
If you want stuff blowing up, I'm your man, but tech stuff, I'm a luddite 110 D250 SE HT
110 USW SOLD
Post #1044891 5th Sep 2024 10:40am
Moo
Ukraine
Call Apple support. They will walk you through it over the phone or can log in and do it for you. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1044894 5th Sep 2024 11:06am
markb110
I’ll stick with Granny Smiths…… Laughing
Post #1044895 5th Sep 2024 11:06am
shaynecm
you will need to plug both displays directly into your mac or get a docking station.
once plugged in go to apple logo top left>settings>display you can then hit the + icon on the right under the screen icon to extend and setup the extra screens.
Post #1044896 5th Sep 2024 11:43am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
depending on the docking station its also hit/miss
Best is to plug each monitor to the Mac, does it have a HDMI on it? plug one in to that, then another usb c socket with a usbc-hdmi adaptor and all will be well, note from memory only one screen can be driven from quite a few docking stations when using a Mac (all the Macs where I work need an extra cable so on hot desks you get both screens working)
then as mentioned above go into display settings and ensure they are not mirror, but extended. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1044907 5th Sep 2024 1:04pm
walfy
I have a screen connected via HDMI and second screen via an adaptor in the USB C port.
I can get all 3 screens to work but can't pass images from screen to screen. I wanted to have the ability to to oen several files from the company server onto at least 2 of the screens. Which isn't working currently 110 D250 SE HT
110 USW SOLD
Post #1044910 5th Sep 2024 1:10pm
Race.it
Display settings and ensure screens are in the order same as desk, as sometimes it can be reversed or one above other etc Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #1044914 5th Sep 2024 1:30pm
excossack
In windows speak, you can either duplicate these displays (sounds like what you have) or extend the displays (sounds like what you need to do) and then you can identify the displays (with a number) and then reorder the displays so you can drag between each one (in what ever order you have the displays laid out)
you might have seen this or similar
https://www.macobserver.com/tips/how-to/co...20step.%20 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1044924 5th Sep 2024 2:51pm
macfrank
This. There are only two alternatives: a) all screens show the same - it seems, that's not the case, good
b) each screen shows one part of a three-part mac desktop - it seems, that's the case, good.
Now, with b) the mac wont know where on your physical desktop you have placed the Mac and the screens. You need to sort them manually. Go to display settings and just drag them left/right.
https://www.eizoglobal.com/support/compati...a/img5.jpg
https://www.eizoglobal.com/support/compati...s-ventura/
Your experience that you can't drag something over to the next screen is probably because you hit the left or right edge of the desktop. If you drag it out the other edge it'll apprear on one of the other screens.
p.s. If you think this is complicated - it's totally intuitive, at least compared to how you need to configure this in Windows. My wife had the exact same problem with her new work desktop last week and I couldn't believe how Microsoft always finds the most complicated way to do things Rolling Eyes
Post #1044953 5th Sep 2024 6:51pm
walfy
Reading all the responses it seems my technophobe is coming therough with what I want to achieve.
When I'm at my clients, I log in via remote desktop. So have full access to their server.
So when I log in I have my desktop showing, but when I open my email or a file/folder it stays on the smae screen as the desktop. I want to be able to drag the email page or the specific file to the other screens.
I have 1 screen into my macbook pro via the HDMI and the second screen in via the USB c via an adaptor. 110 D250 SE HT
110 USW SOLD
Post #1045527 11th Sep 2024 10:23am
excossack
Not sure if its possible to RDP to a remote machine and split that RDP session over multiple screens if that is what you are wanting to do ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1045529 11th Sep 2024 10:50am
walfy
Censored , would make life so simple if I could.
What is RDP? 110 D250 SE HT
110 USW SOLD
Post #1045531 11th Sep 2024 11:01am
excossack
Apologies. RDP - Remote Desktop Protocol 1999 Defender TD5 110
Regards
John M0VAZ
Post #1045536 11th Sep 2024 11:45am
