Home > Technical > Rear Wiper Speed - Puma |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1429 |
Hi, yes, the rear wiper often seems slow and hesitant to start. Especially if it hasn't been used for a while.
Using it a few times seems to help. I've not tried to lubricate it, but that is probably what's needed. |
4th Sep 2024 10:47pm |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 |
Thank you DSC
I shall try that route first before going down the route of removing the motor. I had assumed the rear would have had the same level of speed as the fronts but wasn't sure. P |
5th Sep 2024 5:53am |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 542 |
Noticed similar on my truck.. the rear wiper works but at a slow speed.. as I don't use it I wasn't really bothered, but if I was I'd check the voltage at the motor when off and again when switched on.. if you have a difference of a couple volts that's likely the reason
..just to much drop in voltage.. |
5th Sep 2024 7:58am |
If not used regularly, it's just as likely that the grease in the gear casing has hardened, so increasing resistance. Darren
5th Sep 2024 8:36am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
As LRA mentions, itโll be lack of use.
To be honest that will be common as itโs of little use anyway, anything other than rarely anyway. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช Last edited by custom90 on 5th Sep 2024 12:33pm. Edited 1 time in total |
5th Sep 2024 9:05am |
As always, this forum is fantastic for the feedback and help.
I've got to take my rear door card off for another item I am hoping to fix so will have a look at the voltage and motor itself. My OCD on things working as they should will be in full force this weekend |
5th Sep 2024 10:12am |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 216 |
I'd be interested to know how you get on. Mine is similar but the wiping speed seems to improve when the car has been running for a bit.
5th Sep 2024 12:31pm |
