Home > Technical > Rear Wiper Speed - Puma
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Good day All,
I have searched this from top to bottom but it seems this hasn't been asked.
...and apologies if I'm asking a silly question!
I was out yesterday in the 90 and used the rear wiper for the first time which I found was quite slow to sweep. So before I go about trying to find the cause I thought I'd ask if they are just very slow.
As always, thank you
P
Post #1044837 4th Sep 2024 9:43pm
DSC-off
Hi, yes, the rear wiper often seems slow and hesitant to start. Especially if it hasn't been used for a while.
Using it a few times seems to help. I've not tried to lubricate it, but that is probably what's needed.
Post #1044848 4th Sep 2024 10:47pm
Puma_MOG
Thank you DSC
I shall try that route first before going down the route of removing the motor. I had assumed the rear would have had the same level of speed as the fronts but wasn't sure.
P
Post #1044859 5th Sep 2024 5:53am
andy63
Noticed similar on my truck.. the rear wiper works but at a slow speed.. as I don't use it I wasn't really bothered, but if I was I'd check the voltage at the motor when off and again when switched on.. if you have a difference of a couple volts that's likely the reason
..just to much drop in voltage..
Post #1044874 5th Sep 2024 7:58am
If not used regularly, it's just as likely that the grease in the gear casing has hardened, so increasing resistance. Darren
Post #1044880 5th Sep 2024 8:36am
As LRA mentions, it’ll be lack of use.
To be honest that will be common as it’s of little use anyway, anything other than rarely anyway. TheThunder Rolls🇬🇧🇺🇸
Post #1044884 5th Sep 2024 9:05am
Puma_MOG
As always, this forum is fantastic for the feedback and help.
I've got to take my rear door card off for another item I am hoping to fix so will have a look at the voltage and motor itself. My OCD on things working as they should will be in full force this weekend Smile
Post #1044888 5th Sep 2024 10:12am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
I'd be interested to know how you get on. Mine is similar but the wiping speed seems to improve when the car has been running for a bit.
Post #1044900 5th Sep 2024 12:31pm
