![]() | Home > Maintenance & Modifications > Bilstein Advance Shocks |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
Anyone tried these? I've not heard of them before. Seems to be both conventional and remote reservoir options.
https://www.4x4proyect.com/buy/land-rover/...offroad/en 2007 110 TDCi Station Wagon XS |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
I fitted the advance steering damper when my b6 failed. Works well. If you want to save on vat and duties Mahker sell them. https://shop.mahker.com/product-category/steering-suspension/ WARNING.
This post may contain sarcasm. |
My damper doesn’t do that. Perhaps it’s fitted incorrectly or you have another issue? WARNING.
shaynecm Member Since: 10 May 2024 Location: Norwich Posts: 63 ![]() ![]() |
Unfortunately its the damper when I got it out of the box if the piston is compressed it slowly expands out again. Unless its a faulty unit but think all gas filled ones do this. Causes a very slight bias.
I agree, even though they only open slowly under pressure, if you try and hold one closed they take quite a bit of force to stop opening. Personally I don't think the steering damper should be a gas pressure design. 2007 110 TDCi Station Wagon XS
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
I would be tempted to try these next time. I think the piston cover is essential - my Fox shocks are knackered after maybe 20k miles > 110 XS Double Cab
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 643 ![]() ![]() ![]() |
I had my Fox dampers rebuilt with new Fox damper rods by Prolinx due to pitting if it’s any help
Oh really? What did that set you back? > 110 XS Double Cab
