Home > Maintenance & Modifications > Bilstein Advance Shocks
Bluest
Anyone tried these? I've not heard of them before. Seems to be both conventional and remote reservoir options.
https://www.4x4proyect.com/buy/land-rover/...offroad/en 2007 110 TDCi Station Wagon XS
Post #1044713 3rd Sep 2024 8:33pm
Zed
I fitted the advance steering damper when my b6 failed. Works well. If you want to save on vat and duties Mahker sell them. https://shop.mahker.com/product-category/steering-suspension/ WARNING.
Post #1044716 3rd Sep 2024 8:45pm
shaynecm
The bilstine steering damper is good but has the issue where its biased to one side so im not 100% happy with it as have to keep counter steering.
its lighter/more responsive but prefere the OEM oil filled ones as do alot of long distance.
The shocks are very good though cant fault them.
one thing i am looking into is getting the pin/pin type on the rears (gwen lewis do a kit) that way i can carry less spares. something to look at if your changing anyway.
Got all mine from Mahker. Thumbs Up daves reslly helpfull on setups/need.
Post #1044772 4th Sep 2024 11:54am
Zed
My damper doesn’t do that. Perhaps it’s fitted incorrectly or you have another issue? WARNING.
Post #1048923 16th Oct 2024 8:17pm
shaynecm
Unfortunately its the damper when I got it out of the box if the piston is compressed it slowly expands out again. Unless its a faulty unit but think all gas filled ones do this. Causes a very slight bias.
Post #1048958 17th Oct 2024 8:21am
Bluest
I agree, even though they only open slowly under pressure, if you try and hold one closed they take quite a bit of force to stop opening. Personally I don't think the steering damper should be a gas pressure design. 2007 110 TDCi Station Wagon XS
Post #1048966 17th Oct 2024 10:52am
hank
I would be tempted to try these next time. I think the piston cover is essential - my Fox shocks are knackered after maybe 20k miles > 110 XS Double Cab
Post #1048969 17th Oct 2024 11:52am
Oldowner
I had my Fox dampers rebuilt with new Fox damper rods by Prolinx due to pitting if it’s any help
Post #1049032 17th Oct 2024 11:28pm
hank
Oh really? What did that set you back? > 110 XS Double Cab
Post #1049402 22nd Oct 2024 7:04am
