![]() | Home > Modifications & Maintenance (L663) > Mud Flaps |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3026 ![]() ![]() |
l would go OEM. Try Powerful U.K.
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 140 ![]() ![]() |
Oem wide ones are u.g.l.y. makes the car look like Jughead, wide sticky out things.
I went with Epic Offroad normal looking ones, they do the job, fit well and are cheap enough to warrant easy replacement should you lose one. |
That's interesting. Got any photos?
l guess they aren't available in the U.K. though. |
Sorry not the best photo. Check with epic, they may send to the uk?
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3456 ![]() ![]() |
OEM Classic style, best mud flaps I’ve had on any Land Rover.
![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1469 ![]() ![]() |
OEM. Work a treat and look 'proper'.
![]() ![]() Click image to enlarge Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 242 ![]() ![]() |
Looking great! Just needed one more picture to go haed… thanks!
I have bought a pair of classic OEM from Urban at 192 squid shipped. This was the cheapest OEM pair I could find online. Here for reference (disclaimer: I have no direct interest nor affiliation to this brand) https://houseofurban.co.uk/products/lr-def...erlyEmails |
Here you go
![]() ![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 311 ![]() ![]() |
¡¡Estoy de acuerdo!! En la cola de los guapos, para mí hay dos lugares posibles... el segundo los OEM... pero en el primero, ¡¡CON NADIE!!
Received today the box with the OEM flaps.
However, nobody told me how time consuming was to fit them ![]() If you are planning to DIY allow 1 hour each corner. I have done one ![]() Must be one of the most complicated system on the market ![]() Get yourself psychologically ready to drill your nicely painted (plastic) panels… one way ticket… |
Installing rear mud-flaps was a breeze compared to the front
![]() Done one at the front last night and it show how unfriendly DIY is the Defender. The design of the brackets under the lower front of the wheel arch has definitely changed compared to earlier models. However the design of the flap remain the same. One of the 3 bolts at the front will never go through because there is now a wider bracket. I decided 2 bolts were more than enough. This was the driver side. Tonight I’ll work the passenger side and report. |
Not for the faint hearted!
Sounds like you need a very stiff drink and a long holiday after that!
Great effort. ![]() |
