Home > Modifications & Maintenance (L663) > Mud Flaps |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2868 |
l would go OEM. Try Powerful U.K.
25th Aug 2024 9:44pm |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 134 |
Oem wide ones are u.g.l.y. makes the car look like Jughead, wide sticky out things.
I went with Epic Offroad normal looking ones, they do the job, fit well and are cheap enough to warrant easy replacement should you lose one. |
27th Aug 2024 4:44am |
That's interesting. Got any photos?
l guess they aren't available in the U.K. though. |
27th Aug 2024 6:54am |
Click image to enlarge |
27th Aug 2024 9:15am |
Sorry not the best photo. Check with epic, they may send to the uk?
27th Aug 2024 9:16am |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3412 |
OEM Classic style, best mud flaps I’ve had on any Land Rover.
Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
27th Aug 2024 9:30am |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1407 |
OEM. Work a treat and look 'proper'.
Click image to enlarge Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
27th Aug 2024 11:29am |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 160 |
Looking great! Just needed one more picture to go haed… thanks!
I have bought a pair of classic OEM from Urban at 192 squid shipped. This was the cheapest OEM pair I could find online. Here for reference (disclaimer: I have no direct interest nor affiliation to this brand) https://houseofurban.co.uk/products/lr-def...erlyEmails |
28th Aug 2024 8:11am |
Here you go
28th Aug 2024 9:22am |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 207 |
¡¡Estoy de acuerdo!! En la cola de los guapos, para mí hay dos lugares posibles... el segundo los OEM... pero en el primero, ¡¡CON NADIE!!
28th Aug 2024 1:28pm |
Received today the box with the OEM flaps.
However, nobody told me how time consuming was to fit them If you are planning to DIY allow 1 hour each corner. I have done one tonight, it took a couple of hours including Land Rover instruction and watching videos… Must be one of the most complicated system on the market cause my T6 took at most 30 minutes the 4 corners. Get yourself psychologically ready to drill your nicely painted (plastic) panels… one way ticket… |
29th Aug 2024 10:29pm |
Installing rear mud-flaps was a breeze compared to the front !
Done one at the front last night and it show how unfriendly DIY is the Defender. The design of the brackets under the lower front of the wheel arch has definitely changed compared to earlier models. However the design of the flap remain the same. One of the 3 bolts at the front will never go through because there is now a wider bracket. I decided 2 bolts were more than enough. This was the driver side. Tonight I’ll work the passenger side and report. |
31st Aug 2024 10:03am |
Not for the faint hearted!
2nd Sep 2024 8:51pm |
Sounds like you need a very stiff drink and a long holiday after that!
Great effort. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
2nd Sep 2024 8:55pm |
