Home > Maintenance & Modifications > Spot lights |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20437 |
Yes, you can so long as itโs fused near the Alt in-line.
Take it back to pin 30 on a typical 4 pin NO Relay, 87 out to your lights, then you can sort out the trigger. You probably know this anyway. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
20th Aug 2024 7:53pm |
Nellyd5 Member Since: 07 Jun 2024 Location: Dunbar Posts: 5 |
Thanks custom. That will speed up the install and save routing a cable through the bulkhead
20th Aug 2024 7:59pm |
Click image to enlarge This but using starter as the battery |
20th Aug 2024 8:01pm |
Go for 4mm2 thinwall cable for the supply and load if you can, no smaller than 2mm2, as the bigger cable youโll get less voltage drop but any bigger than 4mm2 then youโll not readily find female spades with locking pins (for the relay) any bigger than that.
Also if you use larger, that will future proof your installation if you want to fit more powerful spotlights or LED etc that draws more current. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
20th Aug 2024 8:10pm |
20th Aug 2024 8:11pm |
