Home > Technical > dash bbulb replacement
joetetley
United Kingdom 1995 Defender 110 300 Tdi SW Epsom Green
Hi all to replace bulbs behind dash in my defender temp gauge and speedo do i need to disconnect any wiring to get proper access to bulbs
thanks
Post #101721 22nd Nov 2011 7:09pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
You don't "need" to but as its only a couple of plugs that are not interchangeable (one for speedo & gauges and one or two for the warning lamp module) it makes access so much easier if you unplug the instrument panel and work with it on your lap or on the bench.
Post #101743 22nd Nov 2011 7:54pm
joetetley
thanks for help
Post #101745 22nd Nov 2011 7:58pm
VOD80
France 2003 Defender 110 Td5 CSW Zambezi Silver
I've just done this. As said, it is one connector for the instruments and two for the warning lights. I found it was better to have the dash panel out as some of the lights were a bit of a fiddle to get back in. It was nice to be doing it in the warm Smile
Post #101818 23rd Nov 2011 8:14am
