Home > Technical > dash bbulb replacement |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
You don't "need" to but as its only a couple of plugs that are not interchangeable (one for speedo & gauges and one or two for the warning lamp module) it makes access so much easier if you unplug the instrument panel and work with it on your lap or on the bench.
22nd Nov 2011 7:54pm |
joetetley Member Since: 09 Dec 2010 Location: leeds west yorkshire Posts: 46 |
thanks for help
22nd Nov 2011 7:58pm |
VOD80 Member Since: 10 Nov 2011 Location: Toulouse Posts: 17 |
I've just done this. As said, it is one connector for the instruments and two for the warning lights. I found it was better to have the dash panel out as some of the lights were a bit of a fiddle to get back in. It was nice to be doing it in the warm
23rd Nov 2011 8:14am |
