Home > Puma (Tdci) > Brake light not responsive |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
Have you checked the switch on the brake pedal, and obviously the fuses.
11th Aug 2024 4:24am |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 107 |
There are two filaments in the bulb.
11th Aug 2024 12:33pm |
robbo22 Member Since: 21 Oct 2023 Location: Leistershire Posts: 23 |
Thank you, filaments are both ok, fuses and ok so it much be the switch? New one on order
11th Aug 2024 3:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17432 |
Have you checked CJB Fuse 13?
Remember also that there are two switches associated with the brake pedal, only one of which operates the brake lights. Make sure if you do change a switch that you change the right one. You might find it worth reading this thread which demystifies - slightly - the strange wiring associated with the 2.4 Puma brake lights. Last edited by blackwolf on 11th Aug 2024 4:21pm. Edited 1 time in total |
11th Aug 2024 4:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20430 |
Switch or grounding probably, try a new switch, test the live and ground.
$W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
Unlikely to be a ground problem since the tail lights apparently work correctly.
11th Aug 2024 4:22pm |
Iโm not surprised switches do wear considering the amount of use they get, same with the clutch switch as well.
Considering that they tend to last quite a long time, Iโve not had to replace the brake switch (yet), but just one clutch switch. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
11th Aug 2024 5:11pm |
FIXED. Brake switch(right hand side) replaced with genuine LR. The one i took of was a aftermarket one. I think the original was replaced 2 years ago - going on the MOT report of brake lamp failure
19th Aug 2024 8:39pm |
