Home > Puma (Tdci) > Brake light not responsive
robbo22
United Kingdom 2009 Defender 110 Puma 2.4 HT Keswick Green
Hi all,
My brake light isnโ€™t responding when i brake. The light it self is working as they light up when dim and full beam are activated. Ive check the earth point on the RHS of the transfer box, that is in order.
Any help would be much appreciated
Post #1042435 10th Aug 2024 6:54pm
landy andy
Have you checked the switch on the brake pedal, and obviously the fuses.
Post #1042462 11th Aug 2024 4:24am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
There are two filaments in the bulb.
Post #1042487 11th Aug 2024 12:33pm
robbo22
Thank you, filaments are both ok, fuses and ok so it much be the switch? New one on order
Post #1042504 11th Aug 2024 3:55pm
Have you checked CJB Fuse 13?
Remember also that there are two switches associated with the brake pedal, only one of which operates the brake lights. Make sure if you do change a switch that you change the right one.
You might find it worth reading this thread which demystifies - slightly - the strange wiring associated with the 2.4 Puma brake lights.
Post #1042506 11th Aug 2024 4:18pm
Switch or grounding probably, try a new switch, test the live and ground.
Thumbs Up $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1042507 11th Aug 2024 4:18pm
Unlikely to be a ground problem since the tail lights apparently work correctly.
Post #1042508 11th Aug 2024 4:22pm
Iโ€™m not surprised switches do wear considering the amount of use they get, same with the clutch switch as well.
Considering that they tend to last quite a long time, Iโ€™ve not had to replace the brake switch (yet), but just one clutch switch. $W33T $0U7H3RN $UG4R
Post #1042512 11th Aug 2024 5:11pm
robbo22
FIXED. Brake switch(right hand side) replaced with genuine LR. The one i took of was a aftermarket one. I think the original was replaced 2 years ago - going on the MOT report of brake lamp failure
Post #1043249 19th Aug 2024 8:39pm
