Home > Td5 > Which dashboard lights should light up on ignition? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5614 |
The handbrake light but you won’t get the brake/tc light as you don’t have abs.
From memory. |
8th Aug 2024 8:48pm |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 333 |
As the brake warning light (also) indicates brake fluid level, should that not come on on ignition? Mine doesn't, I don't recall it ever did or not. Defender 130 HCPU Td5 MY2000
8th Aug 2024 9:02pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 918 |
Not likely the bulb as they are LED. Red brake light should come on with ignition.
Does your brake light come on when you use the park brake? Suggest you check plugs and cap float on top of the brake fluid reservoir. Also consider scanning for codes. Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
8th Aug 2024 9:27pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 894 |
From memory, I think you should see:
- MIL/Engine (amber, extinguishes after a brief moment); - Glow Plugs (amber, extinguishes once plugs are hot); - Brake Fluid/Handbrake Warning (red, stays on until handbrake released); - Oil Pressure (red, stays on until oil pressure exceeds around 0.7bar); - Alternator (red, stays on until the engine is running and charging the battery). If you have ABS/TC, those lights will also appear. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
9th Aug 2024 7:39am |
This is what comes up (obviously this is with ABS).
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
9th Aug 2024 9:32pm |
Thanks guys!
@4RF RDS: in that photo, is your parking brake engaged or does the "brake" light go off after a second or two? Mine doesn't come on on ignition unless I have the parking brake engaged. Defender 130 HCPU Td5 MY2000 |
9th Aug 2024 10:15pm |
It goes out about the same time as the glow plug light. ABS TC goes out after rolling forward 15 feet. (self diagnostic.)
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
9th Aug 2024 10:42pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6596 |
On non ABS, the brake warning light is connected to two things:
Handbrake switch Fluid level switch Neither of these, nor the cluster itself, operate a "bulb check" (the way to check the"bulb" is actually the handbrake switch). 1988 90 Td5 NAS soft top 2015 D90 XS SW |
10th Aug 2024 7:52am |
Thanks guys, that confirms it! I thought I had some sort of issue since my parking brake was engaged, but the light never came on, not even briefly on ignition. I took apart the switch at the bottom of the hand brake and it all now works as what-I-now-believe-is intended. Because I somehow expected a bulb check function because it doubles as the "low fluid" detection, I thought the bulb itself had gone belly up. The other indicators work as described some post above, so I now have nothing to worry about. Thanks again! Defender 130 HCPU Td5 MY2000
10th Aug 2024 8:45am |
