Home > General & Technical (L663) > Arm rests
Hibbert
Arm rests
Is it possible to fit armrests onto defender seats similar to range rovers?
Are the holes behind the leather?
Similar to these:
https://www.aliexpress.com/item/1005006302...Redirect=n
https://www.ebay.co.uk/itm/394203405864?mk...media=COPY
Post #1041666 2nd Aug 2024 12:39pm
LR Nuts
an alternative is, if you have the 'S' model ........
https://www.ebay.co.uk/itm/285802990228?var=587828508343
currently out of stock, but you may want to check with the seller, when stock is due.
I have a 15ltr compressor fridge sat between the front seats, which also acts as an armrest.
Post #1041668 2nd Aug 2024 12:53pm
The_75th
I suspect not - but now they are available on the middle row captain seats on the 130 - maybe that will wake LR up to add them to the front - in which case I imagine a seat swap could be on the cards.
Post #1041834 4th Aug 2024 3:30pm
Crazymind
That would be great to have! I was thinking today for long Journeys 2 armrests would be the best option ever. I am used to the comfort of the 2 armrest on my Caravelle…
Post #1041883 4th Aug 2024 9:39pm
jsinclair
Australia
It can be done. I found a guy on instagram who retrofitted the Range Rover ones to his defender. Let me see if I can find the post.
Post #1041890 5th Aug 2024 1:44am
jsinclair
Australia
I would imagine it requires you to make a hole in the upholstery but it seems the seat frame has the hole to accept the pivot point on the arm rest assembly.
https://www.instagram.com/p/C2vQbKWsMm9/?i...EwNDJvbw==
Post #1041891 5th Aug 2024 1:56am
Hibbert
Thanks for the help Thumbs Up
Post #1042222 8th Aug 2024 12:09pm
