![]() | Home > General & Technical (L663) > Arm rests |
Hibbert Member Since: 28 Jul 2024 Location: London Posts: 9 ![]() ![]() |
Is it possible to fit armrests onto defender seats similar to range rovers?
Are the holes behind the leather? Similar to these: https://www.aliexpress.com/item/1005006302...Redirect=n https://www.ebay.co.uk/itm/394203405864?mk...media=COPY |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
an alternative is, if you have the 'S' model ........
https://www.ebay.co.uk/itm/285802990228?var=587828508343 currently out of stock, but you may want to check with the seller, when stock is due. I have a 15ltr compressor fridge sat between the front seats, which also acts as an armrest. ![]() |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 237 ![]() ![]() |
That would be great to have! I was thinking today for long Journeys 2 armrests would be the best option ever. I am used to the comfort of the 2 armrest on my Caravelle…
jsinclair Member Since: 11 Aug 2020 Location: Brisbane Posts: 46 ![]() ![]() |
It can be done. I found a guy on instagram who retrofitted the Range Rover ones to his defender. Let me see if I can find the post.
I would imagine it requires you to make a hole in the upholstery but it seems the seat frame has the hole to accept the pivot point on the arm rest assembly.
https://www.instagram.com/p/C2vQbKWsMm9/?i...EwNDJvbw== |
Thanks for the help
