Home > Technical > Steering goes solid - 2014 110 2.2tdci |
s55shh Member Since: 30 Dec 2019 Location: staffs Posts: 192 |
exact same symptoms on mine (only under power on Left handers) was the bottom intercooler hose rubbing on the steering column lower spline bolt. Local repairer fitted new column and steering box missing the obvious witness marks on the hose.
19th Jul 2024 9:05am |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 |
Thanks for that. I’ve had a “good” look and can’t see anything of that sort. I’m gonna go out again in a bit and have a proper look
19th Jul 2024 2:07pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5607 |
Shove plenty of rust penetrant /oil on the steering shaft ujs then work round and round a few times.
Give mine a squirt of oil every time I do an engine oil change now. Last edited by landy andy on 19th Jul 2024 8:25pm. Edited 1 time in total |
19th Jul 2024 2:09pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2203 |
This ^^^^ The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey |
19th Jul 2024 6:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7939 |
Drop arm catching steering guard
Steering us Air bubble Some other physical external object restricting rotation. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
19th Jul 2024 8:57pm |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2383 |
Put some oil on the steering column UJ
see if that solves it im putting some on mine atm lol, keeps it free for a month then goes hard again lol so will have to order some new parts for it 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
19th Jul 2024 9:21pm |
Thanks for the suggestions. I’m changing engine oil in a few days so will be under the car. Drove it yesterday for just a few miles with no issue. I’m going to have a proper look all along steering column/rack and oil the hell out of it when I drop my engine oil.
Fingers crossed this is the solution. I like cheap fixes! |
20th Jul 2024 1:53pm |
Just pop the bonnet its accessible from above. 2008 Santorini Black 110 XS USW (Sold)
21st Jul 2024 6:54am |
and check that intercooler hose while you're under there!
21st Jul 2024 10:11am |
Roverdrive Member Since: 11 Aug 2024 Location: Wirral Posts: 11 |
Many moons ago I had something similar happen going around roundabouts in my RRC.
Turned out to be a cardboard disk from inside a bottle top in the bottom of the reservoir. Can't see it being your issue, unless the filter is missing from your header tank. Mike |
11th Aug 2024 11:03am |
