Home > Td5 > Vague steering and advice |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 212 |
OP have you adjusted the steering box on the top nut? Just a quick fix no parts needed but there's a 17mm lock nut and a torx bit on top of the box if you clean it up and make a mark on the the adjusting screw undo the lock nut turn it no more than quarter of a turn but Id recommend half that then tighten the lock nut down that might help but don't go to mad as it can affect the seals/box just a small adjustment is needed. 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
20th Jul 2024 9:46pm |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 |
Thank you all, this site remains the best for helpful advice for experts and novices, without judgement.
(Steering box yes is adjusted and appropriate ball joints on order. ) Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
22nd Jul 2024 7:54am |
