Home > Td5 > Vague steering and advice
Page 3 of 3 <123
United Kingdom 2003 Defender 110 Td5 HT Alaska White
OP have you adjusted the steering box on the top nut? Just a quick fix no parts needed but there's a 17mm lock nut and a torx bit on top of the box if you clean it up and make a mark on the the adjusting screw undo the lock nut turn it no more than quarter of a turn but Id recommend half that then tighten the lock nut down that might help but don't go to mad as it can affect the seals/box just a small adjustment is needed. 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1040542 20th Jul 2024 10:46pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Thank you all, this site remains the best for helpful advice for experts and novices, without judgement.
(Steering box yes is adjusted and appropriate ball joints on order. ) Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #1040681 22nd Jul 2024 8:54am
Zed
Did you get the steering sorted in the end? I ask because I had a similar issue and despite trying all the usual things it was actually fixed by getting the wheels aligned properly. I’d had it done previously by a tyre place but it still felt ever so slightly off so I went to a motorsport specialist with experience of Land Rovers and they found my rear was out of true. Now it drives perfectly and there is no play in the steering. WARNING.
Post #1041587 1st Aug 2024 6:35pm
Page 3 of 3 <123
