Home > Maintenance & Modifications > Rear door handle getting stiffer TD5 90
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Hi, so the rear door handle has become noticably stiffer to lift up, still operational though.
All appears move quite freely when door is open, any ideas?
Cheers Stoker 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #1040185 17th Jul 2024 6:04pm
Mo Murphy
You need more coal ! 😁
The most likely scenario is that your door has sagged a little and the striker requires adjustment.
HTH
50 Shades of Pennine Grey
Post #1040191 17th Jul 2024 7:33pm
chiefstoker
Laughing Laughing
I have adjusted the two screws right up on the rubber buffer. Door doesn't get hardly any use, and I do have a swing away bracket, so shouldn't be much weight on the hinges.
I'll try and have a another fiddle this weekend Mo cheers Thumbs Up 2005 TD5 90 Hard Top
Post #1040313 19th Jul 2024 9:58am
Mo Murphy
Not so much the buffer, stoker, as the whole striker. Slackening the two screws just enough to allow you to move the striker down a little with a light mallet blow. The striker is designed to be adjusted a fair way up and down and in and out, so do not slacken the screws too much, just take the nip off. Gently try the door and if satisfactory nip up the screws again.
HTH
Post #1040352 19th Jul 2024 2:54pm
chiefstoker
So I went to open the door when I got home from work and the handle was stiff as.. Wouldn't budge, so I though, oh fk! How am I going to open the door, just about managed to clamber over the dog cage to try from the inside. But that didn't work. Finally gave it a good tug and the door popped open!
So, took out cage, took off door card.
Everything looks as it should, I think the issue must be in the mechanism on the door 🤔 2005 TD5 90 Hard Top
Post #1040412 20th Jul 2024 8:48am
chiefstoker
HTH
Mo
All sorted now Mo thanks, I fitted new latch mechanism Thumbs Up 2005 TD5 90 Hard Top
Post #1041259 29th Jul 2024 12:03pm
excossack
Mine does the same. Maybe some more adjustment needed on mine. Out of interest what make of latch did you go for? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1041271 29th Jul 2024 2:19pm
Mo Murphy
Thumbs Up
Post #1041296 29th Jul 2024 7:46pm
