Home > Maintenance & Modifications > Changing the diff lock switch on lt230 |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 757 |
Yup, old one out.... New one in nowhere near any oil
7th Jul 2024 1:29pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4222 |
Thanks, I spent a frustrating 30 mins trying and failing to disconnect the electrical plug. I reach it OK over the chassis rail, but no amount of wiggling and poking with a screwdriver would get it to budge. 2007 110 TDCi Station Wagon XS
7th Jul 2024 7:58pm |
You might be better off by removing the cubby box and the panel underneath it and tackle the job from above
8th Jul 2024 6:03am |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 202 |
Definitely a job easier from above 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
8th Jul 2024 6:13am |
Thanks I might have to bite the bullet. I was trying to avoid removing the cubby as I have a Mud locker underneath it with an auxiliary fuse box in there and a rats nest of wiring. 2007 110 TDCi Station Wagon XS
8th Jul 2024 7:17pm |
Did it yesterday through the panel under the cubbybox as suggested. Forearms shredded, precious 19mm spanner hacksawed in half to make a stubby. Once the high/low selector is popped off it not actually that bad of a job. 2007 110 TDCi Station Wagon XS
15th Jul 2024 8:25pm |
