![]() | Home > Maintenance & Modifications > Changing the diff lock switch on lt230 |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 810 ![]() ![]() ![]() |
Yup, old one out.... New one in nowhere near any oil
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4253 ![]() ![]() ![]() |
Thanks, I spent a frustrating 30 mins trying and failing to disconnect the electrical plug. I reach it OK over the chassis rail, but no amount of wiggling and poking with a screwdriver would get it to budge. 2007 110 TDCi Station Wagon XS
You might be better off by removing the cubby box and the panel underneath it and tackle the job from above
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 225 ![]() ![]() ![]() |
Definitely a job easier from above 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
Thanks I might have to bite the bullet. I was trying to avoid removing the cubby as I have a Mud locker underneath it with an auxiliary fuse box in there and a rats nest of wiring. 2007 110 TDCi Station Wagon XS
Did it yesterday through the panel under the cubbybox as suggested. Forearms shredded, precious 19mm spanner hacksawed in half to make a stubby. Once the high/low selector is popped off it not actually that bad of a job. 2007 110 TDCi Station Wagon XS
